December 6, 2020 at 3:47 am
Nguyen Van Toan
SubscriberHello everyone!nI'm simulating FSI with Fluent and Transient structural modules.nThe timestep is 1e-6 (set in Systemcoupling). How can I set time interval to transfer data which is different from timestep? ( That means timestep is 1e-6 but the data is transfered every 1e-3)nThank you so much!n -
December 17, 2020 at 11:03 am
Ashish Khemka
Forum ModeratorHi,nnPlease see if the following post may be of help to you:nnI'm performing one-way FSI simulation with Fluent and Structures using system coupling module.My question is: Is it possible to define a specific time step for Fluent model, other for the Structures model (being a multiple of the Fluent one) and then define a system coupling equal to the Structures?As example: Fluent time step: 0.01Structures time step: 0.1System Coupling time step: 0.1So, fluent model performs 10 time steps and then transfer the data for the structural model.Thankshttps://forum.ansys.com/discussion/20230/is-it-possible-to-define-different-time-step-sizes-in-a-system-coupling-simulation
nRegards,nAshish Khemkan
- The topic ‘FSI with time interval to transfer data!’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
