April 1, 2022 at 10:11 am
ollie_boulton
SubscriberI'm running a Coupled Field Transient model of FSW process. I then run the output file on a cloud server. When inputting the .esav file back into workbench i get the below errors. Can someone help.
I also did a bench mark and run the simulation on my computer which worked fine but when running the same model on cloud i get the same error. All units seem to be the same even in the APDL file. Ive also overrided the units in Analysis Data management to MKS.
Im running it on cloud as the model currently takes over 12hrs on my machine and renders is useless for other work.
April 11, 2022 at 5:16 pmAshish Khemka
Forum Moderator
Ansys employees cannot download the attachments. The unit system message looks like a warning. Can you please share the snapshot from the solver output?
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘FSW Analysis Error with units’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
