function expression
    • aar007
      Hi, I  am trying to write a Function expression but can't input the value axis of z to get the velocity profile = uref(z/zref)^alpha.
       get the error (error at host invalid expression uref(z/zref)^alpha the fluent processor could not be started.
      the z is from the scroll down when I type letter z
      I want the z to be in the z-axis.
    • aar007
      using fluent 19.4
    • Karthik R
      Administrator
      Could you please try something like this?
      uref [m s^-1] * (z / z_ref [m]) ** alpha
      Please see the screenshot.
      Here uref = 0.2, z stands for the z-coordinate, ** is an operator for (power), and alpha = 2
      Hope this helps.
      Thanks.
      Karthik
    • aar007
      it works but when I try computing my inlet conditions in reference value I get *nan* in velocity section. a picture of my domain and coordinates
      my domain
    • aar007
      my inlet is at x=-1 using the magnitude and direction option under velocity specification method
    • Karthik R
      Administrator
      Can you send me the exact formula you are using? And also elaborate on what you would like to see here?
      Thank you.
      Best,
      Karthik
    • aar007
      used the same formula in your first reply. uref [m s^-1] * (z / z_ref [m]) ** alpha. my issue in the reference values. i hope this is clear enough.
    • DrAmine
      That is not a big deal: just input an average velocity in the reference values.
Viewing 7 reply threads
