March 31, 2023 at 2:46 am
April 1, 2023 at 3:33 am
Ilham Rido Arsono
SubscriberHello Mita, in ANSYS simulation, a mass balance calculation is performed to ensure that the mass of fluid entering a domain is equal to the mass leaving the domain. This is an important check to ensure that the simulation results are accurate and reliable.
The mass balance calculation involves evaluating the difference between the mass flow rate at the inlet and outlet boundaries of the domain. If the difference is significant, it indicates that there are errors in the simulation setup or the boundary conditions.
By performing a mass balance check, the user can identify and correct any errors or inconsistencies in the simulation setup, which can help to improve the accuracy and reliability of the simulation results.
In summary, the mass balance calculation in ANSYS is a crucial function that helps to ensure the accuracy and reliability of fluid flow simulations by verifying that the mass of fluid entering and leaving the domain is consistent. Thank you.
- Features of the check case
- Does anyone know what this is caused by? – Cyclone Separator Simulation (CFD)
- Hydrostatic pressure simulation failure on a simple structure like a large aquar
- Error Floating Point Exception
- Heat transfer radiation through glass
- real fundamental difference in true tension body and engineered tension
- Room with Air-Conditioning Vents
- Convergency in mass flow rate
- Function mess balance in fluid flow
- Viscous Models
5326
3311
2471
