Gaining Results for static structural analysis of a hammer
    • dillly96
      Hello all;
      As the title suggests I am trying to get graphical results for the hammer I have created for total deformation, stress and stress.
      However I get the same results each time shown in the images with a 5 step process, I have done more than 5 steps but the results are the same.
      What might have caused this?
    • 1shan
      By default the results are shown for the end of last load step. You can view results at an intermediate step by changing the 'display time' value.
      Regards Ishan.
    • dillly96
      I have changed the display time however the results are still the same and the graph is still a straight line.
      I am expecting the results to be similar to the image attached:
      What is causing this?
    • peteroznewman
      If the value of Force doesn't change from Step 1 to Step 5, that would be the reason Stress doesn't change either.
    • dillly96
      I see, I have fixed the issue by adding the steps and as a result values where plottied, many thanks­ƒæî .
Viewing 4 reply threads
