Photonics
Photonics
Ganhemt Project mistake can you help me
    • acemicellat
    • acemicellat
      Sorry I forget Mistakes ScreenShots
      Staff aren't permitted to open or download attachments so please post the images so we can see them. More details will help put the question in the correct section too.
    • acemicellat
      i create this project but its not run
      And I'll refer you to my previous comment. Insert the image rather than as an attachment.
    • acemicellat
    • acemicellat
      ─░ dont run this project can you help me ?
    • acemicellat
      Thats mistakes
      Thanks one for I think. I assume the file it's asking for is in that folder?
    • acemicellat
      Can you help me mr about this subject
    • Khashayar Ghaffari
      Hi Thank you for reaching out. This is related to product CHARGE. As indicated in the error message you seem to have a conductor material in your simulation without it being used a contact boundary condition. This will prevent the simulation from being run as conductors are simulated in CHARGE only as voltage boundaries.
      Best regards
    • acemicellat
      How can i solve it change CHARGE Simulation Region ?or Elements privates change ....
    • acemicellat
      i change CHARGE Simulation Region but it dont work
      Hi To fix this you need to make sure any objects made of conductor materials are assigned as a contact in your boundary condition; you would have go to your boundary condition settings and assign them to the metal objects.
      I recommend looking into our CHARGE course available on Ansys Learning Hub. This will be helpful in getting you up to speed with using this solver faster.
      Best
Viewing 13 reply threads
