February 3, 2021 at 3:04 pm
mengineerm
SubscriberHello everyone, i have a question about round bodies in spaceclaim.
For a Mechanical Simulation i had to create a Model that consists of some rounded bodies. I used the exact same radius and origins for the bodies, but the bodies look like their faces dont´t exactly touch in some points. When i measure the faces, spaceclaim tells me there is no distance between them, but just by looking at it, it looks slightly different. So my question, is this just a presentation issue of spaceclaim, or should i change my modeling process?
February 4, 2021 at 6:35 amKeyur Kanade
Ansys EmployeeThis could be just visualization issue. nYou can increase rendering by going to File - SpaceClaim Options - Rendering Quality. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
4824
3059
2235
1306
862
