LS Dyna
LS Dyna
Gauge points missing in history -Autodyn
    • jils
      I am running projectile impact simulation using autodyn. I added a number of gauge points and defined various variables to be calculated for these gauge points. When my simulation is completed and I check the history/single gauge plots, I couldn't find the gauge points and associated variables. But when I review the gauge points under parts even the last cycle, they're still there. I see a message which said "Too many time instances to be processed".
      How can i retrieve the gauge points and associated variables?
      Also is there a way to open history, result and summary files outside autodyn so that i can export data to other formats like excel, txt etc. so that I can plot the results the way I want?
      Thanks and regards,
      Jils
Viewing 0 reply threads
