June 25, 2019 at 1:19 am
June 25, 2019 at 6:16 am
jj77
SubscriberSee the help manual for rate independent plast. and generalized Hill. In that example there is some code (below modified using matid, for workbench,, of course you need to understand and find out what material constants to use. Also look on this post/tutorial how to add material models to workbench:
! Define generalized Hill model
/prep7
/prep7
MP,EX,matid,2.0E5 ! ELASTIC CONSTANTS
MP,NUXY,matid,0.3
TB,BISO,matid,1,,1 ! Hardening and reference s
TBTEMP,0
TBDATA,1,300,0 ! Can also BISO or BKIN
TB,HILL,matid
TBTEMP,0 ! HILL TABLE
TBDATA,1,1.0,1.1,0.9,0.85,0.9,0.80
June 26, 2019 at 2:20 pm
PureInsanity
SubscriberMuch appreciated with this tutorial, but I have come to problem with the script:
ANSYS mechanical read an unknown error and directed me to check the Solver Output. It turns out that there is a line that says
"The number of temperature specifications exceeds the maximum of 1 for material number 1. The TBTEMP command is ignored. "
I have inputted multiple temperature specifications because I am doing a thermal analysis. What should I do?
June 26, 2019 at 2:45 pm
jj77
SubscriberAs I said never used this, and the example I showed works, but that has only one temp. So it looks like you can not have more than that according to the message. Perhaps some of the Ansys guys has some more input.
June 26, 2019 at 3:17 pm
jj77
SubscriberI looked in the manual and one needs to increase ntemp in the tb command. So I did that and this works (2 temp.)
/prep7
MP,NUXY,matid,0.3
TBTEMP,0
TB,HILL,matid,2
TBTEMP,22 ! HILL TABLE
TBTEMP,100 ! HILL TABLE
TBDATA,1,0.9,1,0.8,0.85,0.9,0.80
June 26, 2019 at 5:02 pm
PureInsanity
Subscriberworked like a charm. thanks!
June 26, 2019 at 5:04 pm
jj77
SubscriberNoworries. More thanwelcome.
3744
2573
1809
1236
594
