November 16, 2023 at 6:33 am
Anh Van
SubscriberHi folks,
I am trying to import file XML as input of load history data to the force under tabular format. Of course, I can type by hand each element of the tabular as well as copy and paste from file csv containing the target table already. But I wonder if there is a way to convert directly from the CSV file to an XML file, then I can import directly the XML file.?
It would be appriciated if you guys could give me some suggestions, even the example of an XML file containing a table.
For example, I want to import XML file represented the table below.
Time(s) X(N) Y(N) Z(N) 0 0 -10000 0 1 0 -10000 0 2 0 -20000 0 3 0 -300000 0 Thank you so much!
November 16, 2023 at 12:34 pm
Aniket
Forum ModeratorYou can get the format easily by creating a dummy load, and then adding some random values and clicking the export button. (which is just below the import).
-Aniket
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
