Platform
Platform
Genetic Aggregation is default response surface
    • Dragana Jandric
      The Genetic Aggregation response surface automates the process of selecting, configuring, and generating the type of response surface best suited to each output parameter in your problem. From the different types of response surface available (Full 2nd order Polynomial, Non-Parametric Regression, Kriging, and Moving Least Squares), GARS automatically builds the response surface type that is the most appropriate approach for each output, (Figure 1).
    • Keyur Kanade
      Thanks!n
