August 19, 2019 at 7:14 am
ravi123rkj
SubscriberHi,
I am doing the buckling analysis of stepped column. I want to perform non linear analysis but I don't know which strain equation ansys is using when I use geometric non linearity by turning large deflection on.
Thanks
August 19, 2019 at 2:56 pm
SubscriberIf you are asking about solid elements, the strain equation doesn't change when large deflection is turned on. The nodes are updated to the displaced location, a new stiffness matrix is computed and a new force imbalance is computed. This process is iterated until the force imbalance is below the convergence criterion.
August 19, 2019 at 2:59 pm
ravi123rkj
SubscriberHi Thanks for reply.
From where can I see that what type of strain equation ansys is using?
Thanks -
August 19, 2019 at 5:43 pm
Mike Rife
Ansys Employeeravi123rkj - please see the following help section:
ANSYS Help -> Mechanical APDL -> Theory Reference chapters 2 "Structures" and 3 "Structures with Geometric Nonlinearalities".
I think you are asking about the small strain definition versus Hencky strain.
Mike
August 20, 2019 at 3:49 pm
ravi123rkj
SubscriberHi Mike sir,
I have searched that on Ansys help but could not found anything of that sort. Can you please upload this with some screenshots so that I can see where can I found this.
Thanks
2120
1349
1118
461
