3D Design
3D Design
geometry
    • chandu659
      previously i read the same discussion on my kind of error ,I have done everything suggested in the geometry but still am unable to remove the error , when i am creating a boolean operation for geometry it shows that it results to non-manifold geometry .can you please help me to solve  this issue .
      thank you
       i am unable to perform boolean operation ,showing an error it results in a non manifold geometry , i have proceeded to fluent solution ,but my internal geometry is missing .Why i am facing this error ?only cusped geometry are making an error for me
      Does the curved shape touch the enclosure at the blunt end? If so let it stick out by a little bit and try again.
    • chandu659
      facing same error..
    • Keyur Kanade
      are those solid bodies or surface bodies?
      make sure you have solid bodies.
      make use of symmetry.
      split geometries in half and then try boolean.
      Keyur
    • chandu659
      thank you it worked
Viewing 4 reply threads
