February 25, 2022 at 6:57 am
Amruth
SubscriberHello,
The question that I have was already asked by someone but I was not able to follow the response. Nevertheless, my question is that whether it is possible to extract back the mesh and geometry from the cas.h5 and dat.h5 files? Unfortunately, I lost both of them in the process of saving .cas.h5 and .data.h5 files.
Any help is appreciated. Thank you.
Amruth
February 25, 2022 at 10:04 amKeyur Kanade
Ansys EmployeePlease save it as .cas file." target="blank">Reverse Engineering with ANSYS SpaceClaim - YouTube
Then read that file in SpaceClaim and use reverse engineering tools to create geometry from it.
Regards Keyur
February 25, 2022 at 3:51 pmAmruth
SubscriberKeyur,
Thank you for the response and help. I was able to open the file in Space claim. I then saved it as .scdoc file. This opens in the next step ('Mesh') but the original mesh is erased.
As I had set up 'Inflation Layer' in the mesh, I just need to see its details. In order to do this, I tried generating a Report in CFD Post, but even the report only shows the total number of cells and nodes.
Amruth
February 25, 2022 at 4:07 pmRob
Ansys EmployeeThe mesh format doesn't necessarily retain the mesh settings, only the mesh itself. If you used Fluent Meshing you may be able to read the case file back into that and the workflow settings might be retained.
February 25, 2022 at 8:45 pmAmruth
SubscriberRob, thank you for the input
Viewing 4 reply threads- You must be logged in to reply to this topic.
2656
2120
1347
1118
461
