November 14, 2018 at 2:02 am
Rizwan
SubscriberThere are few queries related to rectangular geometry model with edges in y direction both insulated and one edge on x axis maintained at T=0 deg C and the other with some heat flux.There is internal heat generation also.Although the model was developed and solver applied.some help is needed in interpreting the output
-the mesh has 8 nodes and three elements,How many temp.values will ANSYS solver determine?
-which is /are affected when we input the material characteristic -Governing equations,essential boundary conditions,natural boundary conditions
Regards
Rizwan
November 14, 2018 at 9:25 pm
SubscriberRizwan,
I see you want the answers to quiz questions in the edX course.
Why don't you say what you think the answers are and explain why.
This forum is intended to help people use ANSYS, not provide answers to academic quizzes.
November 15, 2018 at 8:53 am
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
