TAGGED: designmodeler, static-structural, structural, structure, workbench
April 25, 2022 at 4:08 am
tumulpurwar
SubscriberHello any one can tell?
The geometry was working earlier properly..but now its giving attachment error
April 26, 2022 at 9:15 amtumulpurwar
SubscriberAnyone would like to tell?
April 26, 2022 at 4:35 pmAshish Khemka
Forum Moderator
Can you try reading the geometry again in SpaceClaim?
Regards Ashish Khemka
April 27, 2022 at 4:26 amtumulpurwar
SubscriberIn spaceclaim it reads, but when i attach as usual in workbench mechanical it gives that error
December 29, 2022 at 6:09 am
bhagwantP
Ansys EmployeeSeems some plugin error.
Is the issue happeing for all files or specific to this file only?
Will you please try to reset ansys and see if it helps.
Thanks
- A solver pivot warning or error has been detected
8808
4658
3151
1680
1470
