October 31, 2018 at 11:25 am
Elias
SubscriberAfter I create a rectangle and exit it doesn't show the green right sign so I can't proceed to the next step.May anybody help please. -
October 31, 2018 at 11:37 am
Naresh Patre
Ansys Employeehello Elias,
I guess you are using Design Modeler for geometry creation. You need to create a solid geometry from the sketch that you created in order to proceed further. Please check out below videos on geometry creation in design Modeler.
October 31, 2018 at 11:40 am
Elias
SubscriberNo dear it's on spaceclaim geometry and it's 18.2 -
October 31, 2018 at 11:53 am
Elias
Subscriber..... As the Cornell professor did -
October 31, 2018 at 11:56 am
SubscriberDear Elias,
I assume you are doing the edX course.
After you draw the rectangle, you must click the 3D button or click the Pull tool (without pulling anything) and a surface will replace the four curves of the rectangle. Then you can exit SpaceClaim and have a green check mark.
But before you open SpaceClaim, go to the properties of the Geometry cell and select the Type to be 2D and not 3D. Then you must also draw on the XY plane in SC.
Peter -
October 31, 2018 at 12:00 pm
Keyur Kanade
Ansys EmployeePlease have a look at
Keyur
October 31, 2018 at 12:56 pm
Elias
SubscriberThat's exactly where I am doing as edx course step but still it doesn't show me the green mark and if it may related it also shown "the geometry editor was closed abnormally" -
November 1, 2018 at 3:24 am
Keyur Kanade
Ansys EmployeeAre you opening SpaceClaim through Workbench?
Can you open standalone SpaceClaim? Can you please go to windows - start and type SpaceClaim. Then open SpaceClaim. Can you open and work in this standalone SpaceClaim?
Also try to reinstall latest version i.e. 19.2.
Keyur
November 1, 2018 at 3:30 am
Keyur Kanade
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1349
1118
461
