3D Design
3D Design
Geometry file conversion
    • bhanu34
      Hi
      Is there any good tool to convert STL to STP?
    • Keyur Kanade
      if stl is simple like box type, then in SpaceClaim you can select body in model tree - use right click - convert stl to solid.
      if geometry is complicated (which is the case for all geometries) then you will need to do some manual work. please check following videos.
      if this helps you, please mark this as 'is solution'.
    • peteroznewman
      and then in SpaceClaim, you File, Save As and choose STEP.
