Discovery Import
Discovery Import
Geometry mssing / not properly captured
    • a.john
      It looks like my geometry is missing some parts? Or the solution does not have information about the thin leading and trailing edges?
      Can I do something to improve this, or maybe this is not an issue in the solution - just something going on with the post processing?
      Thanks
    • Brian Bueno
      If you have not done so already, try increasing the fidelity of the simulation.  Generally speaking, Discovery Live will be less accurate for very thin bodies.  The overall level of accuracy will vary from one system to another depending on hardware.
      For more information on this behavior, please refer to this article, and the article linked at the end discussing the relationship between GPU capacity and accuracy: Discovery Verification and Benchmark Cases
