3D Design
3D Design
Geometry not filled when imported into Designmodeler
    • melalisa96
      Hi all
      I used Fusion360 to draw a simple beam and exported it into iges, step, stl file format and imported into ANSYS for static structural analysis. However, when I opened the geometry in Designmodeler, it isn't filled. Any ideas?
      Melissa
    • peteroznewman
      Hi Melissa,
      When I open DesignModeler 19.2 and use File, Import External Geometry File and point to the attached iges file, I get a solid.
      What version of ANSYS are you using?
    • melalisa96
      Hi Peter
      I'm using the 18.2 version. I could get the solid as well in Designmodeler after I add material instead of add frozen. But I'm not too sure why when I open the object in Model, it appears to be unfilled.
    • melalisa96
      I've tried all other formats available as well but still to no avail..
    • melalisa96
      I also tried to draw the beam in 2D and extrude in Designmodeler but it still gives me the same outcome
    • Keyur Kanade
      Can you please deselect View --> Frozen Body Transparency.
      Hope it helps.
      Keyur
    • melalisa96
      Hi Keyur
      Yup got it. Thanks!
      Melissa
    • Keyur Kanade
      Glad that it worked. Can you please mark this as solved so that it will help others on forum.
      Keyur
Viewing 7 reply threads
