July 1, 2020 at 9:40 am
ANURAGM
Subscriberthe geometry is not loading in the mesh software of ansys fluent. The error messages are as follows
Unable to attach to geometry file C:UsersMANJUNATH VAppDataLocalTempWB_MANJUNATHV_MANJUNATH V_13112_2unsaved_project_filesdp0FFFDMFFF.scdoc. Unable to attach geometry.
PlugIn Error: Failed to import assembly from SpaceClaim. No bodies to transfer.
please help me resolve this issue
July 1, 2020 at 1:43 pm
Ansys EmployeeTry saving the project. Also, what are you trying to transfer? Is it a surface, solid or lines?
July 1, 2020 at 2:07 pm
ANURAGM
SubscriberI am going to transfer solid model and I tried saving it also but still it's not showing geometry in mesh -
July 2, 2020 at 5:16 am
Keyur Kanade
Ansys EmployeeThis could be installation issue.
Please uninstall and install 2020R1 with 'run as administrator'.
if you are using 2D please make sure that you are drawing in XY plane.
Keyur
July 2, 2020 at 6:33 am
ANURAGM
SubscriberI already installed it by run as administrator but still it's not getting resolved -
July 3, 2020 at 4:08 am
Keyur Kanade
Ansys Employeeare you using 2d or 3d?
please test with a small cube.
Keyur
July 4, 2020 at 7:31 am
ANURAGM
SubscriberI am using 3d component. The cube also is not loading -
July 6, 2020 at 7:58 am
Keyur Kanade
Ansys EmployeePlease check if you have write permissions to temp folder.
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
3744
2570
1787
1236
594
