August 26, 2018 at 7:13 am
August 26, 2018 at 11:53 am
SubscriberTry assigning a material that has a density property defined and see if the Mass and Volume are calculated.
In Mechanical, click on the body named SURF under the Geometry branch. In the Details window is a Material branch and an Assignment line. Use the pulldown to select Structural Steel, which is the default material and has a density.
If that worked, you can open Engineering Data and create your own material with a different density, and change the assignment in Mechanical.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2534
2066
1285
1104
459
