June 7, 2018 at 6:05 am
rohit_vs
SubscriberHow I can convert surface mesh to geometry in ICEMCFD?
June 7, 2018 at 6:24 am
Keyur Kanade
Ansys EmployeeHello Rohit,
You can use Edit --> Mesh --> Facets to convert surface mesh to facets.
For more information you can check following online help link.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/icm_help/icm_mm_editmenu.html
Keyur
- The topic ‘Geometry to mesh’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
