July 3, 2019 at 1:57 am
Autonewbie
SubscriberHi,
I am trying to import a geometry file (.iges & .x_t) to APDL but warning and error messages pop out: Line XXX on area YYY is not on the area within a tolerance. This area could have problems in future Boolean operations. (see the BTOL command); Cannot project lines to surface ZZZ. Surface could be twisted or lines do not lie on the surface.
I tried to adjust the Boolean Tolerance but it did not work. Any suggestions are much appreciated!
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3862
2631
1859
1254
600
