Ansys Products
Ansys Products
Get a share/transfer connection in scripting
    • j.renault
      Is it possible to get the connections between the different boxes of a project in workbench (share and/or transfer connections) with a function or a property ?
      I aim to identify the boxes that need to be refresh and then updated after a change in a box that is located in precedding steps on the workflow (at the moment, the preceding box is an "External Model" where I read a *.cdb and the box I would like to identify is a "Mechanical Model").
      Thank you for your help.
    • Aniket
      Assuming you know how to get components in a system, you can use the UpdateUpstreamComponents() function on last component to update all upstream dependencies right?
      template1 = GetTemplate(
          TemplateName="Modal",
          Solver="ANSYS")
      system1 = template1.CreateSystem()
      geometryComponent1 = system1.GetComponent(Name="Geometry")
      geometryComponent1.UpdateUpstreamComponents()
      -Aniket
