July 30, 2019 at 2:03 pm
hocon
SubscriberHow can drawing angle of attack AOA from Ansys Fluent GUI.
July 30, 2019 at 2:55 pm
Ansys EmployeePlease elaborate: you set the angle of attach in the geometry, so you should know that?
July 30, 2019 at 6:43 pm
hocon
SubscriberAh, I forgot mentioning that my geometry is a vertical turbine, so the AOA is changing against azimuth. In the result I can draw the velocity or pressure against azimuth but not the AOA against azimuth from GUI. So question is how can I get the AOA gains azimuth or how to set it up in Fluent?
July 31, 2019 at 11:02 am
Ansys EmployeeYou'll need an expression that's a function of the x,y position of the leading & trailing edge. Sketch the blade position at a couple of locations and figure out the maths you'll need.
One tip: if you label each blade separately and create an isosurface of z (assuming z is up) whilst selecting the blade surface you'll create a line of intersection between the two surfaces. This will help locate the leading & trailing edge positions.
July 31, 2019 at 11:49 am
hocon
SubscriberYour suggestion is that it is theoretical one calculated by azimuth, TSR, and pitching angle so the AOA obtained from post CFD gives no information on the actual behavior of the turbine. what I want to know is the actual AOA and how to do it as the similar way to get a lift coefficient from GUI
August 1, 2019 at 10:52 am
Ansys EmployeeCan you post some images? I'm getting lost as to what the actual problem is.
2534
2066
1285
1104
459
