TAGGED: #mechanical-#workbench, apdl, peteroznewman, PyMAPDL, remote-points
February 12, 2023 at 10:06 pm
iliasse diaz
Subscriber -
February 13, 2023 at 1:50 pm
Chandra Sekaran
Ansys EmployeeThe OPEN and WRITE commands are not APDL commands. Please use *CFOPEN and *VWRITE (and *CFCLOSE)
open('frequency_rotation.txt')
write(unit, 'Frequency (Hz) Rotation_X Rotation_Y Rotation_Z')Also in below do loop I do not see a SET command to change the result set from one mode to another. Use SET command. Also may be you should do *VWRITE inside the DO loop and after *ENDDO use *CFCLOSE
do i = 1, num_freq
*get, my_freq, active,,set,freq
my_rot_x=ROTX(Measure_Pilot)
my_rot_y=ROTY(Measure_Pilot)
my_rot_z=ROTZ(Measure_Pilot)
write(unit, my_freq, my_rot_x, my_rot_y, my_rot_z)
enddo -
February 13, 2023 at 8:20 pm
iliasse diaz
Subscriber/com, *
/com, *******************************************
/com, *
/com, Check rotation result
fini
/post1
set,list
set,1,49,,AMPL ! want amplitude
*get,num_freq,nlst,nfreq
*CFOPEN,unit,'frequency_rotation.txt'
*VWRITE,unit,'Frequency (Hz) Rotation_X Rotation_Y Rotation_Z'
do i = 1, num_freq
*VWRITE,unit,my_freq,my_rot_x,my_rot_y,my_rot_z
enddo
*CFCLOSE,unit
/com, *
/com, *
this not work either. What should i correct ? -
February 14, 2023 at 2:27 pm
Chandra Sekaran
Ansys EmployeeThe *VWRITE command should be followed by format in C or Fortran. For example,
%i,%e,%e,%e,%e
February 14, 2023 at 10:35 pm
iliasse diaz
SubscriberThis is the modified code which follows your advices.
February 15, 2023 at 2:38 pm
iliasse diaz
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3744
2573
1821
1236
594
