Get linearized stress on a path using cyclic symmetry
    • AAAbdelnabi
      I want to get linearized stress on a path using cyclic symmetry in thermal stresses one-way couples model in ANSYS Workbench.
      I am modelling 1/4 pipe with constant temp boundary conditions and  I displacement boundary condition at one of the ends.
      I followed SimuTech Group video " How to Include Cyclic Symmetry and Path Results in ANSYS Mechanical Workbench" where a commands (APDL) is used with a command line or function (cpcyc,all,,999,,45,,0) but the model couldn't solve, said errors and warnings exceeded 200 and  give me this warning:
       *** WARNING ***                         CP =      40.344   TIME= 19:20:58
       Specified constraints on slave degrees of freedom in a coupled set are not allowed.  The constraint on this degree of freedom has been removed: coupled set number 93, slave node 138079, UZ.
      I don't what is wrong with the coupling.
    • Aniket
      Does your model involve large rotations? if large rotations are involved CPCYC will not work and you will need to do a full model for this case.
      Have you specified the coordinate system ID? Is angle 45 degrees? Is match control used to match mesh on the faces?
      -Aniket
