Get material data in ANSYS APDL
    • bhanu34
      Hi
      Does anyone know how to get mat ID of material with certain young's modulus or Poisson's ratio through APDL commands ?
    • sathya
      Hi Bhanu,
      I guess there must be command using *GET.
      In the meantime , you can use MPLIST,ALL to list all material data defined as a text file.
      Then just search for the corresponding magnitudes of EX or PRXY and find the mat ID associated with the data.
    • bhanu34
      Hi Sathya
      Can you please be little more elaborate on *GET command?
      Thanks
    • jpasquerell
      do a *get of the maximum material id number into a parameter- see the help for *GET with the entity of MAT
      create a do loop from 1 to the maximum material id number parameter
      *get of EX for the do loop counter number at the desired temperature - see the help for *GET with the entity of MPLAB  (MPLAB can be any of the actual material property labels including PRXY for Poisson's ratio).
      *IF the EX parameter matches the desired then
      set the output mat id to be the current loop parameter value then *EXIT so no more loops
      *ENDIF
      *ENDDO
    • sathya
      Hi ,
      I am using the following syntax but it is not able to read for discontinuous mat id like 1,50,,etc.
      Can you correct me?
      *ask,ym,Enter the magnitude of EX in system units
      *get,matmax,MAT,0,num,max
      *do,i,1,matmax,1
      *get,prop,ex,i,,,
      *if,YM,eq,PROP,THEN
      mplis,i
      *Exit
      *endif
      *ENDDO
    • jpasquerell
      I ran you commands and they worked for me but you can add another *if level to not test prop vs YM when there is no EX for a mat id as prop is an undefined parameter which has a value of 2**(-100) .
      !*ask,ym,Enter the magnitude of EX in system units
      *do,i,1,matmax,1
      *get,prop,ex,i,,,
      *if,prop,ne,2**(-100),THEN
      *if,YM,eq,PROP,THEN
      mplis,i
      *Exit
      *endif
      *endif
      *ENDDO
Viewing 5 reply threads
