December 28, 2022 at 12:06 pm
narges gh
Subscriberwhich boudry condition is true. i use source for stator and rotor and coil and wall for cooling. but it not cool.why
January 5, 2023 at 12:32 am
Nikhil Tamhankar
Ansys EmployeeHi,
Please make sure that the Heat Transfer Coefficient value you specifiy for the Wall BC is sufficient enough to dissipate the amount of heat you input in the Source BC. Also make sure the Wall surface has a good quality mesh otherwise it could lead to solve issues.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
