Get UPF return value from Mechanical APDL input file
    • harald
      Recently, I started working with UPFs. Right now I chiefly work with UPF-functions, however, I want to use UPF-subroutines soon.
      With UPF-functions I manage to do the following:
      • send messages to the output,
      • calculate within the UPF-Fortran file, and
      • return any variable value via text output.
      Now I want to store the UPF-function's return value as  parameter in APDL. Which APDL command does the magic?
      As you can see below, I use a batch file (Code 1) to run a Mechanical APDL input file (Code 2) in batch mode. Within Code 2, user01.f (*) is set to be an UPF. For testing, I execute user01.f by issuing the command usr1. This command should be replaced by an appropriate one, storing the UPF-function's return value as parameter.I thought on something like *set,myParam,myReturn , but did not succeed up know.
      Finally, a general question: Is the idea of calculating something within a function and handing over the result to APDL okay, or not acceptable at all?
      (*) I copied the file to my working directory, which is available from ANSYS Incv180ansyscustomizeuseruser01.f (OS Windows). The code is also available in ANSYS Help Viewer (Go to (Ctrl+Shift+D) help/ans_prog/Hlp_P_UPFDEFCMD.html#c7K4r2c9lcd ).
      REM set environment variables
      REM https://stackoverflow.com/a/4420078
      REM https://stackoverflow.com/a/11190331
      set ANS_USER_PATH=%~dp0
      set ANS_USE_UPF=TRUE
      REM set working directory
      cd /d %~dp0
      REM launch MAPDL
      ansys180 -b -i input.inp -o output.txt
      REM set environment variable ANS_USER_UPF to FALSE
      set ANS_USE_UPF=FALSE
      Code 1: Batch file used to run the ANSYS input file (Code 2).
      /batch
      /gopr           ! PRINTOUT RESUMED BY /GOP
      *del,all        ! DELETE ALL USER PARAMETERS
      /UCMD,STAT      ! LIST OF USER COMMANDS DEFINED BY /UCMD COMMAND
      /upf,user01.f   ! linking user programmable feature into Mechanical APDL
      usr1            ! which command stores the return value of usr1 to a variable?
      /EOF            ! End Of File
      Code 2: ANSYS input file
Viewing 0 reply threads
