Getting a different inlet velocity value
    • Kauê Castro
      Hello, Im having a rather simple problem: The velocity I get when simulating is different of what I specificated in the boundary conditions panel, Im using a velocity profile that I had previously simulated, that has a max speed of 10.5 m/s approximately.. when simulating, the jet only envolves 1.05 m/s max velocity. Im using only one cell condition that depicts the fluid domain.
      Do the coordinates of the profile file match the boundary it's attached to in the new model?
    • Kauê Castro
      I've made sure it matches yes, including the mesh.
      It should be OK then. Can you post velocity contour plots of the two surfaces with node values off?
Viewing 3 reply threads
