May 19, 2022 at 12:44 am
informalthree
SubscriberHello, I am a student doing research on the performance of airfoils using ANSYS STUDENT FLUENT.
If this helps, I am using a gaming laptop (Acer Predator Helios 300, 16 GB ram, RTX 3060, i5-11400H).
For some context:
-I am able to open the workshop and drag the FLUENT component.
-I am able to open DesignModeler for the geometry and successfully create my model
-I am able to open Meshing and successfully create my mesh.
From here, whenever I double-click the setup to open FLUENT, the FLUENT window opens up briefly. The console then shows this message and error:
Unable to connect to external socket: Error during socket creation
Opening output file:"SolutionResult.xml"
Welcome to ANSYS Fluent 2022 R1
Copyright 1987-2022 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Nov 29 2021 12:10:23 EST Build Id: 10213
Connected License Server List:
This is a student version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "InformalThree" (win64).
ID Hostname Core O.S. PID Vendor
n0 InformalThree 1/12 Windows-x64 19428 11th Gen Intel(R) Core(TM) i5-11400H @ 2.70GHz
host InformalThree Windows-x64 8296 11th Gen Intel(R) Core(TM) i5-11400H @ 2.70GHz
MPI Option Selected: intel
Cleanup script file is C:Users
cleanup-fluent-InformalThree-8296.bat No error handler available
Error: Cortex received a fatal signal (SEGMENTATION VIOLATION).
Error Object: ()
FLUENT does not go beyond this point. After a few seconds, the workshop then tells me that "The FLUENT application failed to start".
Note that FLUENT worked for me late 2021 to early 2022 for a different research.
WHAT MAY HAVE CAUSED THE PROBLEM
-Our university recently acquired a license for the full version of ANSYS. I tried installing it, but failed mid-way due to some license manager complications.
-I uninstalled the licensed version (using only the uninstaller) and kept the student version
WHAT I HAVE DONE THUS FAR
-Uninstalled ANSYS STUDENT using the uninstaller. I also deleted the ANSYS folder using the command prompt.
-Reinstalled ANSYS STUDENT, but still get the same error.
-Tried running my files on my old laptop (HP laptop, 16 gb ram, GTX 950m, i7-6700HQ), and FLUENT runs!
Tried having my friend run the files on his laptop (i3 only) , and it runs as well!
What could be the problem? What should I do?
May 19, 2022 at 9:12 amRob
Forum ModeratorShort answer is we're aware of a problem, and
is the error. This doesn't seem to be restricted to Student, Academic or Commercial licences.
Solution - Fluent works fine in standalone mode which is the short term workaround. Build the geometry & mesh as normal, and in Meshing look in File-Export, you want a Fluent mesh (.msh) file.
Viewing 1 reply thread- The topic ‘Getting a fatal signal error using FLUENT on my current laptop, but not on my old laptop’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
