Getting a figure of HSFLD 242 elements
    • joshuagries
      i am relatively new to ANSYS and APDL. During a project i want to use HSFLD 242 elements to fill a pipe respectively a centrifugal pump. I am using a APDL command from the forum to include this elements and get a figure of them.
    • Dave Looman
      You defined a node with number 'newnode' at 0,0,0.5 yet in the comment to this command you indicated the center of mass was at 0,0,400. If the pressure node is not in the correct location it could create an image like you show.n
    • joshuagries
      Hey,nnThanks for the answer. But thats not the case. The center of mass is correctly set at 0,0,0.5. I just changed the values from another code.
