Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Getting back results in MATLAB via Maxwell scripting
    • KMoula30
      I want to use MATLAB to implement my own optimization algorithms in an electric machine i design, so i want to be able to change a variable (that i manage to do it) and get back lets say the average torque. I understand that i need to use the GetOutputVariables command i try something like this in matlab : invoke(oModule,'GetOutputVariableValue','Torque',{'Time:=','0ms','fractions:=','2'},'Setup1 : Transient','Transient','') but i get back an error
      Any help or guidance would be healpful
      Thank you for you time
    • HDLI
      Could you show and double check recorded VB scripting for it? I think we may miss something in the command line. it seems like after output variable's name of "Torque", it might have an expression defined for it. Thanks.
      HDLI
    • KMoula30
      How can I record a script about getting the value of an output variable?
    • HDLI
      Please go to "Automation -> Record Script " in tools bar, and then redo to set the output variables. After clicking "Stop Script", we could open the recorded script.
      HDLI
    • Supriya
      Can you solve this problem? I also need this help.
    • Ashishkumar Gupta
      Hi @KMoula30 How did u call MAxwell from MATLAB. Did u use actxserver(progid). I converted my MAxwell Electrostatiscs model to VBS and then to .m file. After that I am not able to couple both software. Please help me out
Viewing 5 reply threads
  • The topic ‘Getting back results in MATLAB via Maxwell scripting’ is closed to new replies.
