Getting error while Hooking UDF on Cluster – Error: eval: unbound variable
    • vibration
      Could anyone help me in getting the inlet boundary condition UDF hooked on cluster?
      This is the UDF I am using, which gets compiled successfully on cluster, where it creates two folders under libudf (3ddp_host and 3ddp_node) :
      #include "udf.h"
      DEFINE_PROFILE(in_velocity, thread, position)
      real u_mean = 2;
      real a = 0.05;
      real omega = 252;
      real t = CURRENT_TIME;
      face_t f;
      begin_f_loop(f,thread)
      F_PROFILE(f,thread,position) = u_mean + a*sin(omega*t);
      end_f_loop(f,thread)
      This is the part of the journal file, which I am using:
      ;;;;;;Compiling UDF;;;;;;
      define/user-defined/compiled-functions compile libudf yes velocity-parallel.c "" ""
      define/user-defined/compiled-functions load libudf
      ;;;;;;Mesh Partition;;;;;;
      parallel/partition/auto/use-case-file-method yes
      ;;;;;;Reading in the case file;;;;;;
      rc simulation.cas.gz
      ;;;;;;Inlet Boundary Condition: Velocity Profile UDF;;;;;;
      define boundary-conditions velocity-inlet pipe-inlet no no yes yes yes yes udf in_velocity::libudf no 0 no no yes 250 no no no yes 5 0.022 yes
      This is the part of the error file, which occurred during the hooking process:
      > (pipe-inlet)
      Error: 2.5 > 1 (maximum allowed)
      Error Object: no
      Invalid percentage
      Error Object: no
      Invalid percentage
      Error Object: no
      Invalid percentage
      Error Object: yes
      Invalid percentage
      invalid command [yes]
      P.S. udf is getting compiled without using #if !RP_HOST
    • DrAmine
      First debugging test will be setting and running interactively
