March 16, 2021 at 9:04 am
omkarmadhekar
SubscriberMarch 16, 2021 at 9:16 amKeyur Kanade
Ansys EmployeeThe min orthogonal quality should be below 0.1 to proceed to solver. If it is less than 0.1 then please improve the mesh. nFirst check the locations of the bad elements. Please see following video for the same. you have locations, please check if you can improve mesh using different mesh sizing. Please see following video. this does not help, you may need to check if you can use pinch control or virtual topology. this does not help, please go to geometry and modify or simplify geometry at those locations in SpaceClaim. nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
