December 19, 2022 at 5:33 pm
ferruccio.pisanello
SubscriberHi,
How one can get power in the frequency domain from a time point source monitor? The "results" section of point source monitor has a "spectrum" dataset which contains the E and H fields data as a function of frequency (looks like an fft of E(t) and H(t) fields). But it does not have P for all these frequencies. Also i think point integration is not possible with integrate fuction?
regards
FK
December 20, 2022 at 1:08 am
Guilin Sun
Ansys EmployeeYou can get the Purcell factor from the dipole source, which is dipower_radiated_power/source_power_in_homogeneuous_material
source_power_in_homogeneuous_material can be obtained by sourcepower:
Understanding dipoles in non-homogeneous materials
You can also get the radiation spectrum from the point time monitor.
- Error on Lumerical device
2630
2104
1329
1110
461
