March 22, 2022 at 6:55 am
SCL
SubscriberHello. I'm trying to calculate the coupling efficiency of a tapered waveguide.
I also need to optimize the dimension of the entry facet, and the angle of the tapered portion of the waveguide.
I used to FDTD to obtain the transmission and field profile inside the waveguide after the tapered portion,
but I am only interested in how much energy was coupled to the TE00 mode of the waveguide.
However the field profile seems vastly different from the TE00 mode I obtained using MODE, and I believe modes other than TE00 mode has been coupled with the input Gaussian beam.
How do I extract the power fraction of the TE00 mode? Is there a tool provided by Lumerical / Ansys? Do I have to obtain the field distribution data and do some calculation myself? If so, what kind of theory should I look for?
March 22, 2022 at 10:23 pmGuilin Sun
Ansys EmployeeQ: How do I extract the power fraction of the TE00 mode?
A: you can use port to select TE mode and get its transmission. Please refer port and mode expansion monitor: Ports (FDTD) - Simulation Object Using and understanding Mode Expansion Monitors
You do not need to use the field data and do your own calculation.
A side note: you can use EME to optimize the taper.
- Error on Lumerical device
2688
2138
1353
1136
462
