March 3, 2022 at 6:12 pm
Milad_Mokhtari
SubscriberHello there,
I wanted to start using the time-domain solver. I started with a very simple design. It's an open-ended microstrip line and I wanted to see the input and output voltage waves on my waveport terminal. here is the design:
March 9, 2022 at 12:59 pmPraneeth
Please let us know which version of tool you are using to help us serve you better.
Do you have license to the transient solver in Ansys HFSS?
All the very best Praneeth.
March 9, 2022 at 6:41 pmMilad_Mokhtari
Subscriberthank you for your response.
I'm using the Ansys Electronics 2021 R1 and I do have the license for the transient solver.
The simulation filed is also attached for more info.
Thank you so much in advance for your help.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
459
