June 21, 2020 at 3:10 pm
akasengab1
Subscriberis there a way to multiple select points and get the numerical analysis of multiple points at the same time. At the moment I manually select each point manually and add a solution to it, but if I want to study like 100 or 1000 across the pipe to measure the speed change is there a code I could write or a way to select all of them at once. Many thanks in advance!
June 22, 2020 at 5:04 am
Charudatta Bandgar
SubscriberHello Sengab ,
I am looking into your query and will get back to you with my findings, as soon as possible.
June 23, 2020 at 7:40 am
Charudatta Bandgar
I assumed that you are using Discovery LIVE, from your previous queries. Correct me if I am wrong.
Selecting multiple points is not possible in LIVE, and there isn't a way to select multiple points with a code, to extract results.
You may consider posting it under Discovery LIVE ideas if you think it will be beneficial in future versions.
June 23, 2020 at 8:21 am
akasengab1
Subscriberis there a way I could extract the numerical solutions from points in a form of table or excel file from Ansys Discovery Live?
June 24, 2020 at 6:08 am
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3648
2534
1745
1226
578
