Getting wrong current by external Circuit
    • Lars
      Hello Guys,
      when i Simulate my PSM with an external circuit everything works fine. but if I install a fault in the circuit, the branch currents are too large and i dont know why.
    • Navya C
      Have you considered tracing the max value after the fault is introduced or have you traced directly the max value?
      To consider the max value after fault, you can do as shown in the below screenshots and select the start of range after the fault is introduced.
      Regards Navya
