February 1, 2021 at 6:43 am
ametist91
SubscriberI need an example of a GISSMO damage model for any metal. I will add this situation as a keyword to the WB LSDYNA side.
If you can share an example with me in this regard, I would be very happy. I could not find any literature on the card below. What is the difference between using the old card and using this card? Also, if you have any documents about the new card, I would be glad if you can share it. (I'm looking for other than manuel) And I need sample of any metal material.
February 1, 2021 at 10:38 amErik Kostson
Ansys EmployeeThis video:nnnFebruary 25, 2021 at 3:28 pmramgopisetti
SubscriberHi ametist , why do you are looking for adding GISSMO to the deck, why not model the material with damage criteria. Many inbuilt LSDYNA support good material models such as Johnsone cook with 4 damage variables or Steinberge Guinan Strength for ductile material or use JH1or JH2 material model for the Brittle Material, is there any reason for choosign the GISSMO model. why dont use the simple plastic strain (EPS ) criterial to model the damage by looking into histroy variables. Can you able to elobrate the use of the your model.nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5290
3311
2469
