February 7, 2023 at 5:12 am
abhnv_01
SubscriberI am trying to simulate a heat pipe in (2D) which has three sections:
- Evaporator - Constant heat flux (boundary conditions)
- Condensor - Constant temperature (boundary conditions)
- Adiabatic section - Zero heat flux (boundary conditions)
I am using VOF multiphase model -> Evaporation - condensation model -> Lee model.
Transient simulation with gravity and implicit body force formulation.
Time step size = 0.0001 (1E-04).
The simulation works well for first 10000 time steps (1 seconds of flow time) and then this error where global courant number exceeds 250.
But here is a mystery, the simulation runs well with constant temperature boundary condition at the evaporator.
I want results with constatn heat flux, I am not able to track the error, any help will be highly appreciated.
February 7, 2023 at 6:05 am
SRP
SubscriberHi,
I suggest to try variable time stepping in order to automatically change the time-step. It is better to use the variable time stepping method to control the CFL under limit. The solution will be stable with the variable time stepping method.
Thank you
Saurabh
3744
2573
1797
1236
594
