January 14, 2023 at 9:53 pm
bublee-2016114988
SubscriberHello, I am trying to simulate the wavelength shift that results from the adsorption of gold nanoparticles onto the ring waveguide.
This is my simulation region.
And this paper I am trying to replicate suggests a left shift of the resonant wavelength, but I keep getting a right shift.
Can someone please help me locate what I am doing wrong?
This is what I get:
Parameters: ring: inner radius = 2.95um, outer radius = 3.5um, height = 250nm
bus waveguide: width = 500nm, height = 250nm
Gold nanoparticle: shape spherical, diameter = 80nm
Please help me out, I tried a lot.
January 16, 2023 at 6:03 pm
Guilin Sun
Ansys EmployeeFrom your results, it is obvious that the simulation time is too short: please use 100 times more than the current time. you may also need to use finer mesh at the coupling regions and the nano particle with override meshes.
Please refer this post for more information:
Ansys Insight: Why my simulation result is different from published paper or experiment?
- Error on Lumerical device
2522
2064
1279
1094
456
