Goldak double ellipsoid laser welding
    • HollyFart
      I use an APDL command snippet to achieve a double ellipsoid according to Goldak equation, but the Temperature rise at the end of the welding line is strange and artificial.
      The APDL snippet is:
      CMSEL,ALL
      *GET,EMAX,ELEM,,NUM,MAX
      *GET,EMIN,ELEM,,NUM,MIN
      ALLSEL
      TIME_WELD=80
      DT=1
      A=0.003
      B=0.003
      C1=0.004
      C2=0.016
      TAU=0
      FF=0.6
      FR=1.4
      Q=1000
      VEL=1.73e-3
      NPT=TIME_WELD/DT
      NROPT, FULL
      *DO,i,1,NPT,1
      WTIME=(i)
      TIME,WTIME
      HCENTER=VEL*WTIME
      *DO,jj,EMIN,EMAX,1
      X=CENTRX(jj)
      Y=CENTRY(jj)
      Z=CENTRZ(jj)
      CSI=-Z+VEL*(TAU-WTIME)
      *IF,Z,GT,HCENTER,THEN
      C=C1
      F=FF
      *ELSE
      C=C2
      F=FR
      *ENDIF
      PART1=(6*(3**0.5)*F*Q)/(A*B*C*3.14*(3.14**0.5))
      PART2=(exp(-3*(X/A)**2))*(exp(-3*(Y/B)**2))*(exp(-3*(CSI/C)**2))
      QF=PART1*PART2
      BFE,jj,HGEN,,QF
      *ENDDO
      SOLVE
      *ENDDO
      CMSEL,ALL
      BFEDELE,ALL,ALL
      ALLSEL
      This is when the Laser spot leaves the plate.
      Has anyone a suggestion what went wrong?
      Best regards
      Holly
    • cmcc
      I met the same difficulty. Have you solved the problem?I guess it's because when the reservoir leaves the solid, there's no element in the first half that causes the heat flux to change in the second half, and I don't know if I'm right.
    • SteBir
      lost my password and therefore can't reactivate my account.
      Unfortunately, I haven't solved the problem. I think you are right, but I'm not skilled enough to implement it in the code.
      Do you have any suggestions to fix it in the code?
    • cmcc
      I think this problem arises because you use BFE to apply loads to elements, and maybe you should load the FLUX on nodes use BF,I‘m’ trying it now,If you have any progress, please tell me , thank you!
    • SteBir
      did you solve the issue? I wasn't successful.
    • Karthik R
      Administrator
      If you are not finding a reply here, please create a new post with your detailed question and we will be happy to help.
      Thanks.
      Karthik
Viewing 5 reply threads
