December 15, 2017 at 11:37 pm
Fence14
SubscriberI'm modeling iPhone drop tests in ANSYS to look at the effects of various case geometries, however, I'm having a lot of trouble deciding on how I want to create the gorrilla glass material. Corning provides the Young's modulus, Poissons ratio, shear modulus, and density; thats about it. I don't believe this is enough to fully define the glass (I just want to see the principle stress effects, doesnt need to shatter necessarily). My question is: is there a material in the 18.1 ANSYS explicit dynamics materials library that is remotely similar? Float Glass is the only other glass I identified.
December 16, 2017 at 12:51 am
SubscriberIf you don't yet need to predict failure of the glass, then you have enough material properties to predict stress effects.
I recommend you try Transient Dynamics for simulating a drop test because I had good results and the solution times were reasonable.
I recently tried Explicit Dynamics and found that a simple problem ran for 33 hours on a mesh that was too coarse to be useful.
December 16, 2017 at 1:05 am
Fence14
SubscriberOk thank you! I'll be sure to give transient dynamics a try
December 16, 2017 at 9:43 am
Raef.Kobeissi
SubscriberHow can you study the creeping phenomena in transient dynamics? -
December 17, 2017 at 2:53 am
SubscriberRaef,
Creep phenomena are on very long time scales. Fence14 is simulating drop tests, which means impact on a millisecond time scale.
Cheers,
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5454
3419
2475
1310
1022
