Got a problem with “mpt_accept: error: accept failed: No such file or directory”
    • wuxuetianzi
      Everything is going well until I click "Calculate", this message keeps popping out "999999: mpt_accept: error: accept failed: No such file or directory".
      I have activated VOF, species and solidification models. The UDFs compiled with no error.
      After I did not use these UDFs, the simulation can run with several steps (even though it is diverging finally but at least the simulation can be started).
      hope anyone can help me with that.
      Thanks!
      The mpt error is generally associated with parallel, can you relaunch Fluent in serial and see what happens? There may also be another message in the TUI just above the one you mention: that can be more diagnostic.
    • wuxuetianzi
      Thanks for the reply, after I change to serial, the same problem happened. I have attached error message, hope it is helpful, Thanks!
      OK, run through the UDF and check everything is defined and/or given a value. I think you've missed a definition somewhere (and no, I'm not going to debug the code!).
Viewing 3 reply threads
