Tagged: #mechanical-#workbench, error, gpu-acceleration, mechanical
December 29, 2022 at 1:26 pm
Filip Parol
Subscriberlatly when i'm using my gpu (rtx quadro 6000) to accelerate my calculation using ansys mechanical WB, between substeps i offen geting errors like this:
*** ERROR *** CP = 789.812 TIME= 14:10:30
A generic error has occurred when using the GPU accelerator capability.
Error code = 700 which translates to: an illegal memory access was
encountered. Please rerun without using the GPU accelerator
capability. Please send the data leading to this operation to your
technical support provider, as this will allow ANSYS, Inc to improve
the program.
An error has occurred in the Sparse Matrix Solver while factoring the
matrix. Error code = 215. Please send the data leading to this
operation to your technical support provider, as this will allow
ANSYS, Inc to improve the program.
usualy i'm working with fracture or contact analisys.
when turning off gpu acceleration, case is solved without problems.
has anyone idee what can be wrong? -
December 30, 2022 at 12:31 pm
Aniket
Ansys EmployeeSo does this analysis run ok if you turn off GPU acceleration as shown in image below:
Mechanical>File>Solve Process settings>My Computer>Advanced
\You mentioned Lately, so was this GPU with acceleration working before?
I don't think the GPU you are using, is on the supported GPUs list for 2022R2 for Mechanical APDL: https://www.ansys.com/content/dam/it-solutions/platform-support/2022-r2-gpu-accelerator-capabilities.pdf
-Aniket
December 30, 2022 at 1:01 pm
Filip Parol
Subscriberthx for your reply.
yes, without acceleration it's working fine, yes i turn it of as you showen on the prtsc.
maybe the problem is the version of ansys, before i was using 2019R2 and it was working rly well, now i recive a lot of errors using gpu accel. when i will have time i will instal wb 2019r2 and see if it works well.
December 30, 2022 at 12:41 pm
Ashish Khemka
Ansys EmployeeHi Filip,
SIG$SEGV is short for signal segment violation. Technically, it is described as an incorrect use of pointer or a buffer overflow (memory problems). It is a bug, whenever it happens, but it is difficult to relate the cause to any one particular issue. Based on previous call records, it has happened in the past with distributed solver and rezoning, but is not limited to these applications. Using GPU may be causing it. The two errors indicated apart from segment violation are also related to GPU.
Ashish Khemka
2120
1347
1118
461
