April 13, 2022 at 7:19 pm
April 14, 2022 at 4:21 am
Charudatta Bandgar
SubscriberHello Syed Saif Ali
Quadro M2200 is indeed a supported card (I will still confirm this once), but the VRAM is 4Gb, while it is minimum required, for explore mode to work properly 8Gb is recommended. Can you once confirm if the correct graphic card is assigned for Discovery? Also check if you have not installed the graphic card driver from 5xx.x series, as that has shown some issues in past.
Regards.
April 19, 2022 at 3:45 pm
syed.ali
SubscriberHello,
Yeah Graphic card is correctly assigned. Discovery 2021 R2 was showing no such warnings.
Can you please check where the issue lies?
Thanks,
Ali
3744
2572
1793
1236
594
